Navigate the Flow Graph
Navigating the flow graph means moving from one node to another following the input/output dependencies.
You can follow the graph up and down the cone.
- From the Node Editor, click the Compass icon
- From the Set Viewer, move over a node, right-click to get a pop-up context menu and click .
A window opens that shows the node in focus within the center of the display, with a pane above showing the inputs for the node, and a pane below showing the outputs of the node.
Navigate up or down the cone by double-clicking on one of the inputs or outputs listed in the panes. This shifts the node in focus to the one you double-clicked on. It becomes the node in the center and its inputs and outputs are listed in the two panes.
A right-click on an input or output pops up a context menu where you can choose to edit, navigate, or detach the node. Check the on-line help (<F1>) for more instructions.
% vsx [node-ID]
