Set Viewer
When you select a set by double clicking on it in the Set Browser panel, you display that set in the Set Viewer panel.
- The Vertical Graph View displays the nodes in the set as they appear in the dependency graph, complete with arcs, with the earliest nodes in the dependency at the top.
- The Horizontal Graph View displays the nodes in the set as they appear in the dependency graph, complete with arcs, with the earliest nodes in the dependency graph on the left.
- The Grid View is a compact graphical representation that shows a colored square for each job and a colored circle for each file. Jobs and files are placed on a regular grid. The advantage of this view is the ability to display a large number of elements in a relatively small window.
- The Stat View is a summary page showing textual information about the set.
In the three views showing node, you can select nodes with the mouse and invoke a pop-up menu with the right button. This menu allows you to perform operations on a single node, such as editing, invalidating, and forgetting.
Double-clicking on a node brings up the Node Editor for that node.
A "rubber band" operation (point, click, hold, drag, and release) selects all the nodes that have any pixels within the rubber band area. When you make a selection, the selected nodes are highlighted. If you pop-up the menu while pointing to a node in the selection, the menu operations affect all the nodes in the selection.
