Customize the GUI
Console Window Size
You can adjust the minimum size of the window through the Window Size tab of the Preferences dialog.
Customize Component Graphs
You can also adjust the size and graphing of the components through the Graph tab of the Preferences dialog as shown below. The adjustments include the type of connectors for connecting the nodes, node spacing, whether or not to "break" long rows, and more.
General Customization with vovautoexec.tcl
If a file named vovautoexec.tcl is present in the directory from which vovconsole is started, it is sourced when starting the console. You will need to study the vovconsole code and have Tcl/Tk programming skills to make effective use of this method.
