| Scroll by 1 or 5 units in the direction of the
arrow |
Ctrl-Arrows |
| Node alone and expand: create a set containing
only the current node, then expand to show the inputs and
outputs of the node. This is a combination of the accelerator
'a' and the accelerator 'x' |
A |
| Vertical Graph view |
G |
| Detach selected nodes from the current
set |
D |
| Forget selected nodes |
F |
| Horizontal Graph view |
H |
| Invalidate the selected nodes |
I |
| Toggle Show/Hide Files |
J |
| Grid view (sorry, not easy to remember) |
Q |
| Stats view |
S |
| Touch the selected nodes (toggle status twice
between VALID and INVALID) |
T |
| Expand the current set, showing all inputs and
outputs of nodes in the current set. |
X |
| Zoom out |
Z |
| Node alone: create a set containing only the
current node |
a |
| Down-cone of the current set |
d |
| Node alone and down-cone |
Ctrl-d |
| Edit the current node |
e |
| Fit the image to the size of the canvas |
f |
| Show impact analysis for the current
node |
i |
| Select every node that has a similar status to
any of the statuses in the current set of selected nodes |
m |
| Show the navigation dialog for the current
node |
n |
| Pan the image so that the current location of
the pointer is b at the center of the window) |
p |
| Abort graph layout as soon as possible
(interrupt weight-driven placement optimization) and show a
partially optimized graph. |
q |
| Retrace the selected nodes at normal priority.
You must point to a node or a selection for this accelerator to
have effect. |
r |
| When hovering over a node in the node viewer,
add it to the group of selected nodes. |
s |
| Retrace the selected nodes at HIGH priority. You
must point to a node or a selection for this accelerator to have
effect. |
R |
| Up-cone of the current set |
u |
| Node alone and up-cone |
Ctrl-u |
| Expand the current node, showing its inputs and
outputs |
x |
| Zoom in. In graph and jobs views, if there is a
selection, then the widget will zoom to best show the selected
objects. |
z |
| Select all nodes or blocks in the graph. See
also Ctrl-i and Ctrl-c |
Ctrl-a |
| Clear the selection (See also Ctrl-a and
Ctrl-i) |
Ctrl-c |
| Invert selection (See also Ctrl-a and
Ctrl-c) |
Ctrl-i |
