Access Calculated Inertia
Steps to access Calculated Inertia given axis values:
  1. Select reference system catalog values.
  2. Click on Icon Calculate.
    It will calculate inertia on given axis to compare COG and inertia based on user defined values from refence system catalog and values exist in the system.
    Note: Part Number, Revision, Description, Level, Position, Total Weight, COG, Inertia, COG Calculated, Inertia calculated.
