Set Default MGR for Rooms, Hull zones, Stair Trunks
                Select .
                 Click on Set Default MGR for Rooms, Hull Zones and Stair Trunks button  . .MGR mapping window will display.  Note:  Set Default MGR for Rooms, Hull zones, Stair Trunks
                        button enable only when user selected node in the tree view exist “Rooms,
                        Hull zones, Stair Trunks node.
