Weight & Balance Engineering, also known as Mass Properties Engineering, is the technical discipline which refers
to the prediction, determination, management and tracking of the weight, Center of Gravity, and Moment of Inertia
for a new product.
The Programs > Management page allows you to create and manage programs in the database. A Program structure includes Versions, Variants, and Products
in the order of hierarchy.
WA provides a powerful and comprehensive mission simulation module which allows you to calculate the evolution of the weight
during the flight and to monitor how this curve changes over the product life cycle.
Weight Analytics allows you to add a new Functional View, edit, copy, or delete the Functional Views, sort the nodes in a Functional
View, and manage the Functional View structure.
Weight Analytics allows you to copy the mapping table and Department mapping from the existing Functional View node to the newly created
Functional View.
You can build your own Functional Views from an external Excel file. The uploaded Functional View creates a new Functional
View from an external Excel file or updates the current Functional View by inserting the structure described in the
Functional View.
Department mapping from the existing Functional View node to the newly created Functional
View.
To copy the mapping table and Department
mapping:
Create a new Functional View.
With the cursor at the root level for the newly created Functional View, click
the Copy from icon.
In the Copy From dialog box, select the required level
from the tree view.
The Copy From button is enabled.
Select the Department mapping checkbox and then click
Copy From.
The selected Functional View is copied to the newly created Functional
View.
Note:
The maximum level based on what you have defined is copied while
creating the new Functional View.
If a node already exists and cannot be copied, a message is
displayed.
Select the Copy Mapping Table checkbox and click
Copy From.
The selected node Mapping table is copied and can be viewed in the
View mapping table.
