Weight & Balance Engineering, also known as Mass Properties Engineering, is the technical discipline which refers
to the prediction, determination, management and tracking of the weight, Center of Gravity, and Moment of Inertia
for a new product.
The Programs > Management page allows you to create and manage programs in the database. A Program structure includes Versions, Variants, and Products
in the order of hierarchy.
WA provides a powerful and comprehensive mission simulation module which allows you to calculate the evolution of the weight
during the flight and to monitor how this curve changes over the product life cycle.
Weight Analytics allows you to add a new Functional View, edit, copy, or delete the Functional Views, sort the nodes in a Functional
View, and manage the Functional View structure.
Weight Analytics allows you to define the mapping between Departments and Functional View Nodes. This mapping controls what a user
assigned to a specific Department can see during navigation.
The Data Access section allows you to view the Departments and enable/disable
Functional View node access.
Department Functional View Mapping Weight Analytics allows you to define the mapping between Departments and Functional View Nodes. This mapping controls what a user assigned to a specific Department can see during navigation.
User Data Access Weight Analytics allows you to see how a Department is mapped for each defined Functional View with respect to the selected user.
