Settings
Four buttons give access to the following setting definition:
- Thermal settings – Definition of the temperature of active components. For the considered test this concerns the phase winding and field winding temperatures.
- Power electronics settings - Definition of the power electronics parameters
- Mechanics settings - Definition of mechanical loss model parameters
- Import: To import data/setting/input from a “Characterization - Model - Motor - Maps” test, if possible
For more details, please refer to the document: MotorFactory_SMWF_ISP_IR_3PH_Test_Introduction – section “settings”
