Introduction
The total number of user inputs is equal to 13.
Among these inputs, 5 are standard inputs and 8 are advanced inputs.
Sharing data between tests
An import button is available for allowing sharing the data simulated in Flux between “Characterization / Model / Map” and “Performance mapping / Efficiency map” tests.
Indeed, by implementing the rotor position dependency option for the model map test and efficiency map test of synchronous machines, this update facilitates the seamless transfer of settings, inputs, and crucially, simulated data in Flux between the two tests. As they use the same Flux data in most cases and significant computation time is required to obtain it, users can now accelerate the test resolution and optimize their workflow.
- Reluctance Synchronous Machines - Inner rotor
- Synchronous Machines with wound field – Inner Salient Pole - Inner rotor
Upon completing a model map test, users can activate the import button in the efficiency map test GUI. This enables them to effortlessly import the settings and corresponding Flux data from the previous test, eliminating the need to rerun Flux for identical data, a step that typically consumes a substantial portion of computation time during efficiency mapping.
| Import function in Model Map test and
                                Efficiency Map test to accelerate test resolution. Example for Wound field synchronous machines | |
| 1 | Open model map test environment when an efficiency map test is available for import |
| 2 | Click the import button and import the settings, inputs, and Flux data of the latest efficiency map test |
| 3 | Open efficiency map test environment when a model map test is available for import |
| 4 | Click the import button and import the settings, inputs, and Flux data of the latest model map test |
Standard inputs
Operating quadrants
It defines the quadrants in the Jd - Jq plane where the test will be carried out. Options allow computing and displaying 1, 2 or 4 quadrants.
By default, the considered quadrants are the “1st and 2nd” (i.e., the grid is defined for both negative and positive values of the current in the d axis and positive ones in the q axis). This option is chosen as default because the Synchronous Machine with wound field heritages the characteristic of both Synchronous Machine with Permanent Magnets and Reluctance Synchronous Machines which work respectively in the second and the first quadrant in the motor operating mode.
The other possible values for this input are “2nd”, “2nd and 3rd“, and “all”.
Field Current and line current definition mode
There are two common ways to define the electrical current.
In this case, the current definition mode should be « Density ».
Electrical current can be defined directly by indicating the value of the line current (the RMS value is required) and field current (AC value).
In this case, the current definition mode should be « Current ».
Maximum field current, rms
Maximum field current density, rms
Maximum line current, rms
Maximum current density, rms
Maximum speed
The analysis of test results is performed over a given speed range to evaluate losses as a function of speed, like iron losses, mechanical losses, and total losses.
The speed range is fixed between 0 and the maximum speed to be considered « Maximum speed » (Maximum speed).
Rotor position dependency
Advanced inputs
Number of computed electrical periods
The user input “No. computed elec. periods” (Number of computed electrical periods only required with rotor position dependency set to “Yes”) influences the computation time of the results.
Number of points per electrical period
The user input “No. points / electrical period” (Number of computed electrical periods only required with rotor position dependency set to “Yes”) influences the accuracy of results (computation of the peak-peak ripple torque, iron losses…) and the computation time.
The default value is equal to 40. The minimum recommended value is 20, and the minimum allowed is 13. The default value provides a good balance between the accuracy of the results and the computation time.
Number of computations for If - axis field current
To get maps along the If dimension, the field current is discretized from zero to its maximum value. The number of computation points along the If - axis can be defined with the user input « No. comp. for If » (Number of computations for If - axis field currents).
The default value is equal to 10. This default value provides a good compromise between the accuracy of results and computation time. The minimum allowed value is 5.
Number of computations per quadrant for D-axis and Q-axis phase currents
To get maps in the Jd - Jq plane, a grid is defined. The number of computation points per quadrant along the d-axis and q-axis can be defined with the user input « No. comp. for current Jd, Jq » (Number of computations for D-axis and Q-axis phase currents).
The default value is equal to 6. This default value provides a good compromise between the accuracy of results and computation time. The minimum allowed value is 5.
Number of computations for speed
The number of computations for speed corresponds to the number of points to consider in the range of speed. It can be defined via the user input “No. comp. for speed” (Number of computations for speed).
The default value is equal to 10. The minimum allowed value is 5.
Skew model – Number of layers
When the rotor or the stator slots are skewed, the number of layers used in Flux® Skew environment to model the machine can be modified: “Skew model - No. of layers” (Number of layers for modeling the skewing in Flux® Skew environment).
Mesh order
To get results, Finite Element Modeling computations are performed.
The geometry of the machine is meshed.
Two levels of meshing can be considered: First order and second order.
The default level is second order mesh.
Airgap mesh coefficient
The advanced user input “Airgap mesh coefficient” is a coefficient that adjusts the size of mesh elements inside the airgap. When the value of “Airgap mesh coefficient” decreases, the mesh elements get smaller, leading to a higher mesh density inside the airgap and increasing the computation accuracy.
The imposed Mesh Point (size of mesh elements touching points of the geometry), inside the Flux® software, is described as:
MeshPoint = (airgap) x (airgap mesh coefficient)
Rotor initial position mode
The computations are performed by considering the relative angular position between the rotor and stator.
This relative angular position corresponds to the angular distance between the direct axis of the rotor north pole and the axis of the stator phase 1 (reference phase).
The value of the rotor d-axis location, which is automatically defined for each saliency part in Part Factory, can be visualized in the output parameters in the saliency area of the Motor Factory – Design environment.
