VectorFromScalar
Creates a vector from three scalar tables and stores the result in answer.
- x
 - A scalar value table.
 - y
 - z
 - sysid
 - A system ID or keyword (default = 0).
Outputs
- answer
 - A vector value table.
- x, y, z, and answer must be real bound to the same entity type, and of the same domain (complex or real).
 - sysid is a string containing an ID or keyword that defines the system
          the vector will be created relative to:
- “0”: Global (the default)
 - A positive integer: a system ID in the model
 - “elem”: the elemental coordinate system
 - “anal”: the nodal analysis system
 - “ply”: the elemental ply system
 - “mat”: the elemental material system
 - If x is a constant value table (created by the Constant operator), no records will be added to the answer table.
 - If a record cannot be found in all three input scalar tables, no vector will be created.
VectorFromScalar(xs,ys,zs)XML Example
<call name="VectorFromScalar" x="xs_tab" y="ys_tab" z="zs_tab" answer="ans_tab" />
