Project
Stores the projection of lhs onto rhs into answer.
- lhs
 - A vector value table.
 - rhs
Outputs
- answer
- lhs, rhs, and answer must be in vector format.
 - If lhs is a constant value table (created by the Constant operator), no records will be added to the answer table.
project(lhs,rhs)XML Example
<call name="Project" lhs="lhs_tab" rhs="rhs_tab" answer="ans_tab" />
