Rendering Models
Realistic Rendering is a new graphics mode that is based off of the physically based rendering model approach that allows for the flow of light to be rendered more accurately as it would be in the real world.
A new workflow emphasizing the multicore profile for standard crash post processing use cases.
ON THIS PAGE
ON THIS PAGE
