Access the Context Menu
To access the Image Plane context menu:
                From the Results Browser, right-click on an image plane
                    within the tree structure.
                The context menu is displayed.
                Click on one of the available options.
Create Creates a new image plane. Any number of image planes can be created. Note: Image planes will be listed in the Results Browser tree structure under the Image Planes folder, and each image plane will contain a single static image or video.Edit Edits the options/settings for the currently selected image plane. The Image Plane tab is automatically displayed upon selection of the Edit option. Delete Deletes the selected image plane with a confirmation message. Rename Displays the Rename dialog, which allows you to rename the selected image plane. The image plane label is a convenient way for you to organize various media. The actual file name is displayed in the Image Plane tab (when activated by the Edit option). Show Displays the selected image plane in the modeling window. Hide Turns off the display of the selected image plane in the modeling window. Show Manipulator Displays the graphical manipulator in the modeling window for the currently selected image plane. The graphical manipulator allows you to modify the location and shape of the image plane interactively. Note: The graphical manipulator is linked to the Image Plane tab, therefore the display of the graphical manipulator is turned off whenever the Image Plane tab is closed. See the Display State of Graphical Manipulators topic for additional details.Hide Manipulator Hides the graphical manipulator for the currently selected image plane in the modeling window. Note: This option is only active when there is a graphical manipulator currently displayed in the graphics area. See the Display State of Graphical Manipulators topic for additional details.
