Composites Library
The Composites library contains operators that calculate multiple composite failure theories.
- Solver profiles: OptiStruct and Nastran
 - Applicable only for 2D shell elements with property definition as per Zone Based Modelling with PCOMPG and/or PCOMP
 - Output Format: Composite Stress in Tensor Format (for example, *.op2)
