HyperView Composite libraries expose different flavors of the
        general criterion of PUCK failure theory for 2D plane stress.
    Simple Puck
          - Fiber Failure
          - Where
               or
               if
               or
          - Matrix Failure
          - Where
           or
           if
             or
          - The final failure is given as:
    Modified Puck
          - Fiber Failure
          - Where
               or
               if
               or
          - Matrix Failure
    Puck2D
          - Fiber Failure
          - Where
               or
               if
               or
          - Matrix Failure
          - Three failures modes are developed:
                - Mode A
                - When
                - Mode B
                - When
                 and
                - Mode C
                - Otherwise
          - Where, for all the above equations we define:
          - Being
and
, in Puck’s theory, the inclination parameters respectively on
            the tension and compression side.
          - The following values are used:
                    GFRP |
                    CFRP |
                    OTHERWISE |
                    0.25 |
                    0.30 |
                    0.2 |
                    0.30 |
                    0.35 |
                    0.3 |
      PuckFT(tensor,xt,xc,yt,yc,s,criterion,output2d,sets,plies,elems,parts,props,pool_name,layer_index,opt_str)
    Arguments
          - tensor
          - Stress table
          - xt
          - Allowable tensile stress in ply material direction 1
          - xc
          - Allowable compressive stress in ply material direction 1
          - yt
          - Allowable tensile stress in ply material direction 2
          - yc
          - Allowable compressive stress in ply material direction 2
          - s
          - Allowable in-plane shear stress
          - criterion
          - Puck Criterion: simple, modified, General2D, Glass2D, Carbon2D (D=simple)
          - output2d
          - Puck 2D output mode: value or mode (0=fiber failure, 1,2,3=matrix failure mode A,B,C)
            (D=value)
          - sets
          - Set table (D=NULL)
          - plies
          - Ply table (D=NULL)
          - elems
          - Element table (D)
          - parts
          - Part table (D)
          - props
          - Property table (D)
          - pool_name
          - Pool name (D=@current_pool)
          - layer_index
          - Layer index (D=@current_slice_index)
          - opt_str
          - This is an optional argument, which can passed if needed (D=option).
