Spatial Library (Beta)
The Spatial (Beta) library contains functions that deal with minimum distance and result mapping.
The minimum distance and value mapping functionality has been updated since it was first introduced, however it is still in beta form for testing purposes. These operators may change before they are finalized.
The result is a vector that can be plotted directly or contoured.
