Output Parameters
The output parameters section of the Expression Builder allows you to define the data type label and output for the newly created result.
Label
The label will become the data type name, and must be unique for the analysis. This label defines the user-defined data type name that will appear when selecting results from the results browser or from the post-processing panels.- Character Reference
 - Character Name
 - Ampersand
 - Left Angle Bracket
 - Right Angle Bracket
 - Quotation Mark
 - Apostrophe
 - Left Square Bracket
 - Right Square Bracket
 - Left Curly Brace
 - Right Curly Brace
 - Backslash
 - Colon
