The resulting failure index in Hoffman’s theory for an orthotropic lamina in a general
        state of plane stress (2D) with unequal tensile and compressive strengths is given by:
      Where:
         are the maximum allowable stresses in the
            1-direction in tension and compression,
            2-direction in tension and compression,
         is the allowable in-plane shear
            stress
      HoffmanFT(tensor,xt,xc,yt,yc,s,sets,plies,elems,parts,props,pool_name,layer_index,opt_str)
    Arguments
          - tensor
          - Stress table
          - xt
          - Allowable tensile stress in ply material direction 1
          - xc
          - Allowable compressive stress in ply material direction 1
          - yt
          - Allowable tensile stress in ply material direction 2
          - yc
          - Allowable compressive stress in ply material direction 2
          - s
          - Allowable in-plane shear stress
          - sets
          - Set table (D=NULL)
          - plies
          - Ply table (D=NULL)
          - elems
          - Element table (D)
          - parts
          - Part table (D)
          - props
          - Property table (D)
          - pool_name
          - Pool name (D=@current_pool)
          - layer_index
          - Layer index (D=@current_slice_index)
          - opt_str
          - This is an optional argument, which can passed if needed (D=option).
