Considering the above expression for the Failure Index if we set:
      Being  a given factor of safety, then the reserve factor formula can
        be evaluated as below:
      TsaiWuRF(tensor,xt,xc,yt,yc,s,f12,FoS,sets,plies,elems,parts,props,pool_name,layer_index,opt_str)
    Arguments
          - tensor
          - Stress table
          - xt
          - Allowable tensile stress in ply material direction 1
          - xc
          - Allowable compressive stress in ply material direction 1
          - yt
          - Allowable tensile stress in ply material direction 2
          - yc
          - Allowable compressive stress in ply material direction 2
          - f12
          - F12 experimental factor
          - FoS
          - Factor of Safety (D=1.0)
          - s
          - Allowable in-plane shear stress
          - sets
          - Set table (D=NULL)
          - plies
          - Ply table (D=NULL)
          - elems
          - Element table (D)
          - parts
          - Part table (D)
          - props
          - Property table (D)
          - pool_name
          - Pool name (D=@current_pool)
          - layer_index
          - Layer index (D=@current_slice_index)
          - opt_str
          - This is an optional argument, which can passed if needed (D=option).
