Combine
Combines two tables together into a single table. Matching records are replaced or summed.
- src
 - A value table.
 - with
 - A value table.
Outputs
- answer
 - A value table.
 - sum_count
 - A scalar value table (default="null")
- src, with, and answer must be of the same type, binding, and format.
 - If sum_count is specified, it must be a scalar table bound to the same entity type as src, with, and answer.
 - The sum_count argument controls how values from
            src and with are combined into
            answer.
- If sum_count is “null”, answer will contain records from src and with. In the case where a matching record ID exists in both src and with, answer will contain the record from with.
 - If sum_count is a valid scalar table, it will contain a count for each record added to answer. In the case where a matching record ID exists in both src and with, answer will contain the sum of src and with.
 - Combine can be used to average values between two tables by dividing answer by sum_count.
N/AXML Example
<call name="Combine" src="src_tab" with="with_tab" answer="ans_tab" />
