Arithmetic Operators
Arithmetic operators contain both unary and binary operations.
Unary Operators
Unary operators have two parameters: src and answer. Both of these parameters follow the syntax based upon the equation below:{op}(src) = answerwhere:- op
 - The unary operation: Inverse (inv), SquareRoot (sqrt), Power (^), etc.
 - src
 - The input table to the operator op.
 - answer
 - Contains the result if the operation is successful.
Binary Operators
Binary operators follow a syntax based upon the following equation:lhs {op} rhs = answerwhere:- op
 - The binary operator: Add (+), Subtract(-), Multiply(*), Divide (/).
 - lhs
 - the left-hand side of the binary operator op.
 - rhs
 - The right-hand side of the operator.
 - answer
