Multiply
Multiplies records in lhs with rhs and stores the result in answer.
- lhs
 - A value table.
 - rhs
 - A value table.
Outputs
- answer
 - A value table.
- lhs, rhs, and answer must be of the same binding.
 - lhs, rhs, and answer must be of the same format (after promotion).
 - If lhs and rhs are both constant value tables (created by the Constant operator), no records will be added to the answer table.
 - If lhs and rhs are vectors or tensors, a component-wise multiplication is performed, functioning as a scale operation).
lhs * rhsXML Example
<call name="Multiply" lhs="lhs_tab" rhs="rhs_tab" answer="ans_tab" />
