Reciprocal
Stores the reciprocal of src in answer.
- src
 - A value table.
Outputs
- answer
 - A value table.
- src, and answer must be of the same binding and format.
 - If src is a constant value table (created by the Constant operator), no records will be added to the answer table.
 - If a record in src contains any zeros, no value will be placed in the answer table.
 - If src contains multiple components (a vector or tensor value), answer will contain the same number of components with each being the reciprocal of src (for example, if src is a vector, answer will contain components of 1/x, 1/y, and 1/z).
recip(src)XML Example
<call name="Reciprocal" src="src_tab" answer="ans_tab" />
