Absolute
Stores the absolute value of src in answer.
- src
 - A value table.
Outputs
- answer
 - A value table.
- src, and answer must be of the same binding and format.
 - If src is a constant value table (created by the Constant operator), no records will be added to the answer table.
abs(src)XML Example
<call name="Absolute" src="src_tab" answer="ans_tab" />
