Dot
Stores the scalar product of lhs and rhs into answer.
- lhs
 - A vector value table.
 - rhs
Outputs
- answer
 - A scalar value table.
- lhs and rhs must be in vector format.
 - answer must be in scalar format.
 - If lhs is a constant value table (created by the Constant operator), no records will be added to the answer table.
dot(lhs,rhs)XML Example
<call name="Dot" lhs="lhs_tab" rhs="rhs_tab" answer="ans_tab" />
