Cos
Stores the cosine of the src in answer.
- src
 - A value table.
 - format
 - deg (default) or rad.
Outputs
- answer
 - A value table.
- src and answer must be of the same binding and format.
 - If src is a constant value table (created by the Constant operator), no records will be added to the answer table.
 - src must be a real value table, and it must be consistent with the format argument.
cos(src)XML Example
<call name="Cos" src="src_tab" answer="ans_tab" />
