ATan2
Stores the arctangent of the rhs/lhs src in answer.
- lhs
 - A value table representing a x-coordinate.
 - rhs
 - A value table representing a y-coordinate.
 - format
 - deg (default) or rad.
Outputs
- answer
 - A value table.
- lhs, rhs, and answer must be of the same binding and format.
 - If lhs and rhs are both constant value table (created by the Constant operator), no records will be added to the answer table.
 - lhs and rhs must be a real value tables.
 - If format is "rad" the values store in the answer table will be radians, otherwise the values will be in degrees.
atan2(lhs,rhs)XML Example
<call name="ATan2" lhs="x_tab" rhs="y_tab" answer="ans_tab" />
