ATan
Stores the arctangent of the src in answer.
- src
 - A value table.
 - format
 - deg (default) or rad.
Outputs
- answer
 - A value table.
- src and answer must be of the same binding and format.
 - If src is a constant value table (created by the Constant operator), no records will be added to the answer table.
 - src must be a real value table.
 - If format is "rad" the values store in the answer table will be radians, otherwise the values will be in degrees.
atan(src)XML Example
<call name="ATan" src="src_tab" answer="ans_tab" />
