Volume
Calculates the solid/shell volume.
- elems
 - An element entity table.
 - thickness
 - A shell thickness scalar table.
 - parts
 - A part entity table.
 - coords
 - A coordinate vector value table.
Outputs
- answer
 - A scalar value table.
- Only shell and solid elements are processed.
 - Thickness and parts arguments default to NULL.
 - If thickness and/or parts are NULL, only solid elements will be processed.
 - All vectors in coords must be relative to the global system.
 - Composite thickness is unsupported at this time.
Volume(thickness,parts,coords,elem)XML Example
<call name="Volume" elems="elem_tab" coords="coord_tab"
parts="part_tab" thickness="thickness_tab"
answer="ans_tab" />
