MaterialAxisVector
Transforms a vector relative to the elemental material system to the global system.
- elems
 - An element entity table.
 - coords
 - A coordinate vector value table.
 - systems
 - A systems entity table.
 - mattheta
 - A scalar table of material angle offsets (default=”null”).
 - parts
 - An part entity table (default=”null”).
 - props
 - A property entity table (default=”null”).
 - vector
 - A vector relative to the material system.
Outputs
- answer
 - A elemental vector value table.
- All vectors in coords must be relative to the global system.
 - Solid material systems require part and property tables, and both must be passed.
 - Two methods for material orientation are supported: an angle offset relative to the element system, and the projection of a system onto the surface of the shell.
 - The vector string is a space-separated list of three scalar values.
MaterialAxisVector(elems,coords,systems,mattheta,parts,props,vector)XML Example
<call name="MaterialAxisVector" vector="1 0 0"
coords="coord_tab" systems="sys_tab" elems="elem_tab"
mattheta="theta_tab" answer="ans_tab" />
