ScalarID
Creates a scalar value table from entity IDs.
- src
 - An entity table.
 - system
 - Reference, analysis, or null (default = “null”).Important: This input is only valid only if the src table is nodal.
Outputs
- answer
 - A scalar table containing the IDs attached to the entities in src.
- It is necessary to use ScalarID in conjunction with binding change operators to visualize property or material IDs.
 - To create scalars of nodal reference system IDs, set system to ‘reference’.
 - To create scalars of nodal analysis system IDs, set system to ‘analysis’.
 - To create scalars of nodal IDs, leave system unset or specify ‘null’.
 - In the case when processing material or property IDs for composites, it is necessary to inherit the layer list from a model table that contains layer data (for example, inherit=”PCOMP_THETA” with Nastran) on the dataset.
ScalarID(src,system)XML Example
<call name="ScalarID" src="part_tab"
answer="ans_tab" />
