Area
Calculates the shell area.
- elems
 - An element entity table.
 - coords
 - A coordinate vector value table.
Outputs
- answer
 - A scalar value table.
- Only shell elements are processed.
 - If the answer scalar table is bound to nodes, the nodal shell area will be calculated; otherwise, the shell area will be calculated.
 - All vectors in coords must be relative to the global system.
 - Nodal shell area is the sum of element area divided by the number of nodes per element for all adjacent elements.
Area(elem,coords)XML Example
<call name="Area" elems="elem_tab" coords="coord_tab"
answer="ans_tab" />
