Supported Roles in Panopticon Real Time
There are four roles supported in Panopticon Real Time:
Role |
Description |
Administrator |
Allowed to perform the following: · View, rename, move, copy, upload, download, interact, and publish/republish workbooks into folders to which the user has permissions to · Add, rename, or remove folders and subfolders and manage users and groups that should be granted or denied access · Import or export workbooks bundle · Administer the server which includes: o manage data templates o create global data extracts from connectors o create and manage alerts and specify the email address of the user or group who will receive the alert o view and manage plugin subscriptions o manage caches o specify logging level and view and copy logs o create and manage scheduled tasks o create and manage global parameters o manage workbook themes o view logged in users to the server and log them out o view server settings, set the file logging level, and clear cache |
Viewer |
Allowed to view and analyze fully interactive dashboards. This is the default role assigned to users that cannot be mapped to other roles. |
Designer |
Allowed to perform the following: · View, create, upload, rename, move, copy, merge, download, remove, workbooks, and publish/republish them into folders to which the user has permissions · Import or export workbooks bundle · Add, rename, or remove folders and subfolders and manage users and groups that should be granted or denied access · Create and manage global parameters · Create and manage alerts and specify the email address of the user or group who will receive the alert These topics are discussed in Altair Panopticon Web Authoring Guide. |
Anonymous |
Allowed to view workbooks if authentication.required is set to false. |
Depending on the authentication or user management mechanism used, the role that a user should have is specified and then mapped to a group set in Panopticon.properties.
Property |
Description |
Default Value |
access.administrator.groups |
The role that is mapped to the administrator group. |
admin |
access.default.roles |
The default roles applied to all users of the server. For example, if access.default.roles=DESIGNER,ADMINISTRATOR and a user with a VIEWER role logs on to the server, then the user will simultaneously have a VIEWER, DESIGNER, and ADMINISTRATOR roles. A blank value for access.default.roles is equivalent to ANONYMOUS. A blank value or the value ANONYMOUS will NOT block users from authenticating. NOTE: The roles that can be assigned in this property can only be ADMINISTRATOR, VIEWER, ANONYMOUS, and/or DESIGNER. This property is case sensitive. |
VIEWER |
access.designer.groups |
The role that is mapped to the designer group. |
designer |
access.viewer.groups |
The role that is assigned to the viewer group. |
NOTE |
· Group sets can be added for a role, separated by a comma. · To be able to use all of the features of Panopticon Real Time, a user is required to have Designer and Administrator roles. · When using Altair Units licensing, different user roles will check out different numbers of Altair Units.
Normally, you should use role mapping to control user access. This way you can manage access in the same place that you manage your users without having to reconfigure the server.
In some scenarios, it may be impossible to set up appropriate roles for Panopticon in your external system, or you may want to make one-off exceptions for specific users. As a workaround for these cases, you can also explicitly list individual users and their access in the server configuration with the access.administrator.users, access.designer.users, and access.viewer.users properties.
