Altair® Panopticon
Properties: Panopticon
The majority of configuration options for the server are set in the Panopticon.properties file in the <appdata> directory (e.g., C:\vizserverdata\). If this file does not exist when the server starts, it will create it with all default values. When the server starts after an upgrade, it may add new properties and remove deprecated ones.
You can optionally move sensitive properties like passwords and URLs from this file, where they are stored in clear text, into a file named Secret.properties in the same directory. The Secret.properties file stores values encrypted, and you can manage it with PCLI. A property can only be defined in one of these files at a time.
The following properties can be set in the property files:
Property
Access
Attribute
access.administrator.groups
The role that is mapped to the administrator group.
Default Value
admin
Property
Access
Attribute
access.administrator.users
Normally administrator access should be handled with the access.adminstrator.groups mapping, but for scenarios where the authentication cannot provide roles or you want to make exceptions for specific users, you can list individual usernames in this property.
Any user listed here will get administrator access, regardless of their roles. Separate multiple users with the access.list.delimiter.
Default Value
Property
Access
Attribute
access.default.roles
The default roles applied to all users of the server.
For example, if access.default.roles=DESIGNER,ADMINISTRATOR and a user with a VIEWER role logs on to the server, then the user will simultaneously have a VIEWER, DESIGNER, and ADMINISTRATOR roles.
However, if no default roles are wanted, then leave the property blank.
NOTE: The roles that can be assigned in this property can only be ADMINISTRATOR, VIEWER, ANONYMOUS, and/or DESIGNER. This property is case sensitive.
Default Value
VIEWER
Property
Access
Attribute
access.designer.groups
The role that is mapped to the designer group.
Default Value
designer
Property
Access
Attribute
access.designer.users
Normally designer access should be handled with the access.designer.groups mapping, but for scenarios where the authentication cannot provide roles or you want to make exceptions for specific users, you can list individual usernames in this property.
Any user listed here will get designer access, regardless of their roles.
Default Value
Property
Access
Attribute
The value delimiter to use when parsing access groups.
Examples:
access.list.delimiter=,
access.administrator.groups=group1,group2
The groups are mapped to {'group1', 'group2'}
access.administrator.groups=group1;group2,group3
The groups are mapped to {'group1;group2', 'group3'}
access.list.delimiter=;
The groups are mapped to {'group1', 'group2,group3'}
Default Value
',' (comma)
Property
Access
Attribute
access.viewer.groups
The role that is assigned to the viewer group.
Default Value
Property
Access
Attribute
access.viewer.users
Normally viewer access should be handled with the access.viewer.groups mapping, but for scenarios where the authentication cannot provide roles or you want to make exceptions for specific users, you can list individual usernames in this property.
Any user listed here will get viewer access, regardless of their roles.
Default Value
Property
Alert
Attribute
alert.creation.only.by.administrators
Enable or disable whether only the Administrators can create alerts.
Default Value
false
Property
Alert
Attribute
alert.detailed.logging
Enables or disables extra alert logging.
Default Value
false
Property
Service authentication level
Attribute
authentication.domain
The default domain information for user authentication.
Default Value
Property
Authentication: Filter Token
Attribute
authentication.filter.authenticate.token
Applies only if authentication.type is set to FILTER or is blank. If this property is set to true, the server will validate the token on incoming requests. If set to false, it ignores the token and authenticates based on the rest of the request instead.
Default Value
false
Property
Authentication: Header
Attribute
authentication.header.role.delimiter
The delimiter used to separate the roles. Example: role1,role2,role3
Default Value
, (Comma)
Property
Attribute
authentication.header.roles
The name of the header that contains all the roles.
Default Value
Property
Attribute
authentication.header.rolesdynamic
Supports the ability to create dynamic roles using free form patterns or string replacement.
To create dynamic roles, use '{header value to be used}'.
Example: authentication.header.rolesdynamic={HEADER_ROLES},financials,role_for_company_{HEADER_COMPANY}
Given this table:
KEY
VALUE
HEADER_ROLES
designer, watcher
HEADER_COMPANY
industrials, consumers
Then the roles to create the authentication token will be the following:
·         designer
·         watcher
·         financials
·         role_for_company_industrials
·         role_for_company_consumers
Default Value
Property
Attribute
authentication.header.username
The name of the header that contains the username
Default Value
Property
Attribute
authentication.header.validate.token
If set to true, the authentication will validate the token. If set to false, the authentication of every request will be based on headers.
Default Value
Property
Authentication: Logout
Attribute
authentication.logout.redirect.url
Takes a URL as a parameter. Clicking the logout button redirects the user to the specified URL.
If this property is not set, user will be returned to the start page of Panopticon.
Default Value
Property
Authentication: OAuth 2.0
Attribute
authentication.oauth2.client.id
The ID of the OAuth 2.0 client.
Default Value
Property
Attribute
authentication.oauth2.client.secret
The secret used by the OAuth 2.0 client.
Default Value
Property
Attribute
authentication.oauth2.identity.attribute.roles
The attribute that will be extracted from the identity response and used as the role.
Default Value
Property
Attribute
authentication.oauth2.identity.attribute.roles.pattern
Takes regex used to extract the roles from the OAuth 2.0 server identity response.
For example, the returned string:
cn=admin,ou=groups,dc=openam,dc=openidentityplatform,dc=org,cn=designer,ou=groups,dc=openam,dc=openidentityplatform,dc=org
contains two roles, admin and designer
The regex to extract the roles is cn=([^,]+).
Default Value
Property
Attribute
authentication.oauth2.identity.attribute.username
The attribute that will be extracted from the identity response and used as the username.
Default Value
Property
Attribute
authentication.oauth2.identity.method
The method on how the access token is passed along in the identity request. Supported values are QUERY, BODY, and HEADER.
Default Value
QUERY
Property
Attribute
authentication.oauth2.identity.url
The URL to the REST service that provides details about the authenticated user.
Default Value
Property
Attribute
authentication.oauth2.login.callback.url
The callback URL. The URL should be the same as one of the specified callback URLs used by the client. The URL should refer to Panopticon Real Time.
Default Value
Property
Attribute
authentication.oauth2.login.redirect.url
Redirects the user to the specified URL after successfully logging in. This property can be left blank, in which case the user is redirected to the URL they requested to access.
Default Value
Property
Attribute
authentication.oauth2.login.response.type
The response type. The only response type that is currently supported is code.
Default Value
Property
Attribute
authentication.oauth2.login.scope
The requested scope.
Default Value
Property
Attribute
authentication.oauth2.login.url
The URL to the OAuth 2.0 login resource.
Default Value
Property
Attribute
authentication.oauth2.logout.redirect.url
Logging out revokes the token from the authentication server if the property authentication.oauth2.logout.url is set to the revocation URL. If this property is not set, the server will only remove its own token.
If none of these properties are set, the server will attempt to redirect to the start page of the Panopticon when logging out.
Default Value
Property
Attribute
The URL to the OAuth 2.0 logout resource.
Default Value
Property
Attribute
authentication.oauth2.token.method
The method on how the token should be retrieved. Supported values are QUERY, BODY, and HEADER.
Default Value
Property
Attribute
authentication.oauth2.token.url
The URL to the OAuth 2.0 token resource.
Default Value
Property
Attribute
authentication.required
The property that will make the authentication required. It will force the user to login in order to use any of the services provided by the server.
Default Value
true
Property
Attribute
authentication.role
The authentication role.
Default Value
Property
Authentication: SAML
Attribute
authentication.saml.assertion.roles
User attribute for roles configured in the IdP.
Default Value
authentication.saml.assertion.roles=roles
Property
Attribute
authentication.saml.assertion.username
User attribute for username configured in the IdP.
Default Value
authentication.saml.assertion.username=name
Property
Attribute
authentication.saml.assertionconsumerservice.url
The URL to the Panopticon assertion consumer service.
URL: [Protocol]://[Host]:[Port]/[Context]/server/rest/auth/login
Example: http://localhost:8080/panopticon/server/rest/auth/login
Default Value
authentication.saml.assertionconsumerservice.url=http://localhost:8080/panopticon/server/rest/auth/login
Property
Attribute
authentication.saml.certificate.name
The name of the certificate used to validate signature and/or sign outgoing SAML messages
Default Value
authentication.saml.certificate.name=saml-cert
Property
Attribute
authentication.saml.certificate.password
The password of the certificate used to validate signature and/or sign outgoing SAML messages.
Default Value
Property
Attribute
authentication.saml.challenge.required
This property determines whether the IdP-first authentication with SAML is enabled or not. To enable, set this property to false.
Default Value
true
Property
Attribute
authentication.saml.identityprovider.certificate.file
Takes a file path to a certificate file that contains the IdP’s public key.
Default Value
Property
Attribute
authentication.saml.identityprovider.logout.url
The URL to the IdP logout service.
Default Value
Property
Attribute
authentication.saml.identityprovider.signature.validation.required
Specifies whether to require a valid IdP signature to be present on the SAML response. Default value is false.
Default Value
false
Property
Attribute
authentication.saml.identityprovider.url
The URL to the IdP login service.
Default Value
authentication.saml.identityprovider.url=https://192.168.99.100:443/simplesaml/saml2/idp/SSOService.php
Property
Attribute
authentication.saml.keystore.file
The location of the Keystore file that contains the certificate.
Default Value
authentication.saml.keystore.file=D:/SAML/mykeystore.jks
Property
Attribute
authentication.saml.keystore.password
The password to the Keystore file.
Default Value
Property
Attribute
authentication.saml.keystore.type
The key store type. Possible values are JKS, JCEKS, PKCS12.
Default Value
JKS
Property
Attribute
authentication.saml.login.redirect.url
Default Value
Property
Attribute
authentication.saml.logout.redirect.url
Redirects the user back to the specified URL after logging out. This is mainly used with a proxy. In which case, Panopticon Real Time does not know the endpoint which the user is going towards to, and therefore cannot redirect the user back to the Overview page. If you are using OpenAM this is required, otherwise this property can be left blank.
Default Value
Property
Attribute
authentication.saml.openam.meta.alias
The meta alias for the IdP if you are using OpenAM.
Default Value
Property
Attribute
authentication.saml.protocolbinding
Protocol binding for the use of SAML authentication. Possible values are HTTP-Redirect, HTTP-POST, HTTP-Artifact, HTTP-POST-SimpleSign, or SOAP.
Default Value
HTTP-Redirect
Property
Attribute
authentication.saml.provider
The IdP provider. Possible values are OPENSAML, OPENAM.
Default Value
OPENSAML
Property
Attribute
authentication.saml.serviceprovider.id
The ID of the service provider configured in the IdP.
Default Value
authentication.saml.serviceprovider.id=DwchFrontLocal8080
Property
Service authentication login request
Attribute
authentication.timeout.callback
The timeout (in milliseconds) for the user between initiated login and callback. The default value is five minutes.
Default Value
300000
Property
Authentication: Token
Attribute
authentication.token.cookie
The name of the cookie used to store the authentication cookie. Must be unique for each server instance on the host.
Default Value
ptoken
Property
Attribute
authentication.token.cookie.httponly
This property determines how the browser will treat the cookie. If set to true, the cookie will be stored in the browser as a HttpOnly cookie and will not be available to the JavaScript. If set to false (default), the cookie will be stored in the browser as https and will be accessible to the JavaScript.
Default Value
false
Property
Attribute
authentication.token.cookie.samesite
Used by browsers to control the behavior of same or cross origin requests. There are three possible values. Lax, Strict, and None. Please refer to browser specific documentation for its usage.
Default Value
Lax
Property
Attribute
authentication.token.cookie.secure
The property determines how the browser will treat the cookie depending on the security of the connection. If set to true, when the browser receives a secure cookie (HttpOnly cookie), you will not be able to transmit it unless the connection is secure.
Default Value
false
Property
Attribute
authentication.token.domain
Specifies the token cookie domain.
Default Value
Property
Attribute
authentication.token.in.login.response.body
This property determines if the REST login response body should contain a token info.
NOTE: Does not affect the SOAP login response body.
Default Value
false
Property
Attribute
authentication.token.persistence
This property is used to determine if the token should persist if the browser is closed or if it should only last while the browser is open. There are two possible values: PERSISTENT and SESSION. PERSISTENT will persist the token in the browser even if the browser has been closed and reopened. SESSION will remove the token from the browser if it is shutdown.
IMPORTANT:
After modifying the property value to SESSION, ensure to clear the AppData/Token folder before starting the server.
Default Value
PERSISTENT
Property
Attribute
authentication.token.refreshable
This property determines if the token can refresh itself. The Web client can identify if the token is about to expire and then request a new token with the existing token. A token is refreshable if the property is set to true. The token will expire and invalidate the user session if the property is set to false.
Default Value
true
Property
Attribute
authentication.token.secret
The secret is used to sign the token. The secret will be auto-generated when the server starts for the first time.
NOTE: This value should be kept a secret.
Default Value
Auto-generated
Property
Attribute
authentication.token.validity.seconds
The number of seconds that the token should be valid.
Default Value
604800
Property
Attribute
authentication.type
The type of the authentication mechanism that will be used on the Server.
Default Value
BASIC
Property
Bookmark Administration
Attribute
bookmark.administration.only.by.administrators
Set to true if only Administrators should be able to manage bookmarks.
Default Value
false
Property
Attribute
bookmark.show_shared
Allows private bookmarking. If set to true, all of the users will be able to view each other’s bookmarks. If set to false, bookmarks will only be viewed by the one who created them.
Default Value
true
Property
Cache
Attribute
cache.data.datasource.enabled
Enable or disable the caching of the data source.
Default Value
true
Property
Cache
Attribute
cache.data.datasource.size
The data source cache size.
Default Value
100
Property
Cache
Attribute
cache.data.datasource.type
The data source cache type.Allowed values: MEMORY, NONE
Default Value
MEMORY
Property
Cache
Attribute
cache.data.datatable.enabled
Enable or disable the caching of the data table.
Default Value
true
Property
Cache
Attribute
cache.data.datatable.size
The data table cache size.
Default Value
100
Property
Cache
Attribute
cache.data.datatable.type
The data table cache type.Allowed values: MEMORY, NONE
Default Value
MEMORY
Property
Cache
Attribute
cache.data.query.enabled
Enable or disable the caching of data query.
Default Value
true
Property
Cache
Attribute
cache.data.query.size
The data query cache size.
Default Value
100
Property
Cache
Attribute
cache.data.query.type
The data query cache type.Allowed values: MEMORY, NONE
Default Value
MEMORY
Property
Cache
Attribute
cache.plugin.id
The ID of the plugin that will be used to store data. Possible values: BinaryTableFile-Cache.
Default Value
Property
Cache
Attribute
cache.purge.condition
Defines the condition for when the cache will be purged. Allowed values: NONE, MEMORY
Default Value
MEMORY
Property
Cache
Attribute
cache.purge.condition.memory.threshold
Defines a percentual memory threshold for cache purging, when the cache.purge.condition = MEMORY.
Default Value
80
Property
Cache
Attribute
cache.purge.enabled
Enables scheduled cache purging.
Default Value
true
Property
Cache
Attribute
cache.schedule.clear.enabled
Enable the cache clearing schedule. This is scheduling the clear cache operation which will remove all the expired cache entries.
Default Value
true
Property
Cache
Attribute
cache.service.enabled
Enables or disables the service cache.
Default Value
true
Property
Cache
Attribute
cache.service.type
The service cache mechanism being used.
Default Value
IN_MEMORY
Property
Client Cache
Attribute
client.cache.control.age.max
Controls the cache-control max-age header for static content.
Default Value
31536000
Property
Client Data
Attribute
client.data.load.transport
Configure the transportation protocol for loading data from the Web client. Possible values: WEBSOCKET, LONG_POLLING.
NOTE: This property has been deprecated. Refer to Setting the Transportation Protocol for more information.
Default Value
WEBSOCKET
Property
Server Cluster
Attribute
cluster.bully.bind
The URL of the server in bully mode. This should be the URL to the panopticon server web application on the server itself, by which is reachable from the other servers.
Default Value
Property
Server Cluster
Attribute
cluster.bully.boot
Comma-separated list of server URLs in bully mode.
At least one of these servers should be running at all time for the bully mode to work correctly. The URLs should be the same as the cluster.bully.bind value on each boot server.
Default Value
Property
Server Cluster
Attribute
cluster.bully.id
The unique server ID in bully mode.
Can be any string, but do not change it after the server has participated in a cluster -- the other servers will store it and expect it to identify the same server in the future. The running server with the lowest ID lexicographically will be leader.
Default Value
Property
Server Cluster
Attribute
cluster.fixed.leader
The leader URL in fixed mode.
This should be the URL to the panopticon server web application on the preset leader server, by which it is reachable from the follower servers. Leave blank on the leader server itself.
Default Value
Property
Server Cluster
Attribute
cluster.kubernetes.container_name
Optionally name of the container that runs the Panopticon server, if the pod also runs other containers. If left blank, the first container will be used.
Default Value
Property
Server Cluster
Attribute
cluster.kubernetes.id
Set to the name of the pod that runs the container.
Default Value
(blank)
Property
Server Cluster
Attribute
cluster.kubernetes.label_selector
Standard Kubernetes label selector that should only match the pods that are running the server.
Default Value
Property
Server Cluster
Attribute
cluster.kubernetes.peer_path
Path to the web application on each server. For example, "panopticon/", or "/" if you have deployed to Tomcat's root.
Default Value
Property
Server Cluster
Attribute
cluster.mode
NONE (default), FIXED, BULLY, or KUBERNETES
Default Value
Property
Server Cluster
Attribute
cluster.shared.secret
Any alphanumeric string.
Secret used to encrypt a challenge in peer-to-peer communication handshake. Needs to be the same, and non-empty, on all connected servers.
Default Value
Property
Server Cluster
Attribute
cluster.shared.store.shared_directory.path
Shared store location in SHARED_DIRECTORY mode.
This path must be reachable by all connected servers, and must point to the same physical directory on all of them.
Default Value
Property
Server Cluster
Attribute
cluster.shared.store.type
PRIVATE_DIRECTORY (default) or SHARED_DIRECTORY
The shared store is used to store information that should be synchronized between servers but is not content, for example authentication tokens. If you have a tightly-coupled cluster, e.g., behind a load balancer, it is recommended that you configure this as a shared directory.
Default Value
Property
AMPS Connector Custom Authentication
Attribute
connector.amps.authenticators
This property is required when a custom authenticator is needed for AMPS connection. A custom authenticator needs be implemented as java .JAR file. The property excepts a JSON object, where key is fully qualified name of the Authenticator Java class, and values are list of constructor parameter names, e.g., “{"com.panopticon.examples.amps.AMPSClientAuthenticator":["User","Shared Key"]}”
Default Value
Property
Connector File Path
Attribute
connector.common.filepath.link.disabled
If set to true, the Link to File option will not be available.
Default Value
false
Property
Host Lookup
Attribute
connector.kdb.host.lookup.script
Full path of the shell script file that is accessible on the server. When set, before making a new kdb+ connection, this script is executed to get the host info. This property helps in overriding connection details entered inside the kdb+ connector UI centrally, and may help when different authentications are set at kdb+ like Kerberos/Custom etc. The output of this script is expected to be a JSON object like below.
{ "host": "localhost", "port": 5001, "username": "", "password": "" }
NOTE: Starting with the 21.2 release, the the kdb+ connection pool feature of Panopticon (kdb.connection.pool.xx) can be used together wth the host lookup. So any new connection request from the pool, will first execute the script set here, to get the host info before the pool is looked up for available connections.
Examples:
·         For Windows
connector.kdb.host.lookup.script=E://Data/host.bat
·         For Linux
connector.kdb.host.lookup.script= /etc/panopticon/appdata/host.sh
Default Value
Property
Host Lookup
Attribute
connector.kdb.host.lookup.script.arguments
Delimited set of arguments to be passed to the script when it is executed. ’{host},{port},{userid},{password}’ is the default value, and these parameters are mapped to respective settings in the connector UI i.e., the value entered against these settings in the connector UI are passed as arguments to the script.
This property can be extended or updated if you want to pass other datatable parameters as arguments. System parameter like {_user_id} or {_workbook_folder}, if added to the data table, can also be used. If the value of some parameter is null or empty at the time of execution of the script, two single quotes are passed (‘’) against that parameter, this is to make sure that arguments count matches the arguments set at this property.
Default Value
Property
Host Lookup
Attribute
connector.kdb.host.lookup.script.arguments.delimiter
Used to split the arguments set at above property.
Default Value
Property
Host Lookup
Attribute
connector.kdb.host.lookup.script.timeout
The timeout (in milliseconds) to wait for the host lookup script to run and return the host info.
Default Value
5000
Property
Amazon Kinesis – Data Streams connector
Attribute
connector.kinesis.datastreams.accesskeyid
The Access Key ID from the AWS account.
Default Value
Property
Attribute
connector.kinesis.datastreams.secretaccesskey
The Secret Access Key ID from the AWS account.
Default Value
Property
OAuth Token URL
Attribute
connector.oauth.tokenurl
Sets the server-wide token URL.
Default Value
http\://localhost\:5000/oauth/token
Property
Python connector
Attribute
connector.python.host
The default Python Pyro instance host address.
NOTES:
For connector.python.host, connector.python.password, connector.python.port, and connector.python.serializertype properties:
·         If set in the Panopticon.properties file, these fields will be hidden in the Python connector and will be applied to the Python transform as well.
·         These default Panopticon Real Time connection properties will be applied at runtime.
These default Panopticon Real Time connection properties will override old Python connection settings.
Default Value
Property
Python connector
Attribute
The default HMAC Key.
Default Value
Property
Python connector
Attribute
The default Python Pyro host port.
Default Value
Property
Python connector
Attribute
The default Python serialization type. Possible values are serpent or pickle.
Default Value
Property
Rserve connector
Attribute
connector.rserve.host
The default Rserve host address.
NOTES:
For connector.rserve.host, connector.rserve.password, connector.rserve.port, and connector.rserve.userid properties:
·         If set in the Panopticon.properties file, these fields will be hidden in the Rserve connector and will be applied to the R transform as well.
These default Panopticon Real Time connection properties will override old Rserve connection settings.
Default Value
Property
Rserve connector
Attribute
The default password that will be used to connect to the Rserve service.
Default Value
Property
Rserve connector
Attribute
The default Rserve host port.
Default Value
Property
Rserve connector
Attribute
The default user Id that will be used to connect to the Rserve service.
Default Value
Property
Data Store
Attribute
datastore.connection.schema
Name of the database schema to be used for creating or managing objects inside database.
Default Value
dbo
Property
Data Store
Attribute
datastore.type
Controls which data store connector should be used. Valid values are MonetDB, MSSQLServer and PostgreSQL.
Default Value
MonetDB
Property
Data Store
Attribute
datastore.connection.jndi
JNDI resource name for the connection e.g., jdbc/MyDB. More details on how to configure JNDI is at JNDI Connection Details section.
Default Value
Property
Data Store
Attribute
datastore.connection.url
JDBC connection URL for the database e.g., jdbc:monetdb://localhost:49153/PanopticonDataStore
This property value is discarded If datastore.connection.jndiproperty is set.
Default Value
Property
Data Store
Attribute
datastore.connection.driverclassname
Fully qualified Java class name of the JDBC driver used for the connection.
Default Value
org.monetdb.jdbc.MonetDriver
Property
Data Store
Attribute
datastore.connection.username
Username for the connection. Only required when using connection URL.
Default Value
Property
Data Store
Attribute
datastore.connection.password
Password for the connection. Only required when using connection URL.
Default Value
Property
REST Documentation
Attribute
documentation.enabled
Enable or disable the OpenAPI Specification documentation for the REST interface.
Default Value
false
Property
Alert
Attribute
email.address
The email address where the alert will be sent from.
Default Value
Property
Email
Attribute
email.host
The host name used by the email server.
Default Value
Property
Alert
Attribute
email.password
The email password, if available.
Default Value
Property
Email
Attribute
email.port
The port number used by the email server.
Default Value
Property
Email
Attribute
email.security.mode
The security mode used when sending emails. Possible values: NONE, SSL, TLS.
Default Value
NONE
Property
Email
Attribute
email.username
Email account username.
Default Value
Property
Error Message
Attribute
error.default.message
Defines a generic error message override.
Default Value
Property
Image export
Attribute
export.image.height
The default height for an exported image.
Default Value
768
Property
Image export
Attribute
export.image.width
The default width for an exported image.
Default Value
1024
Property
File Upload
Attribute
file.upload.size.max.bytes
Limit for files size (in bytes) to be uploaded through the web browser (i.e., workbooks, streams applications, streams data sources).
Default Value
30000000
Property
Copy Image
Attribute
image.client.timeout
Specifies a timeout (in milliseconds) when producing an image or PDF. If it takes longer than the timeout, the process will be interrupted, and the image/PDF will not be produced.
Default Value
600000
Property
kdb+ Connection Pooling
Attribute
kdb.connection.pool.max.size
The maximum number of connections that will be kept open for reuse for each kdb+ server (among kdb+ servers that use the same username, password, TLS flag, and timeout), so that established connections can be reused when subsequent queries come in for the same server. A benefit of the connection pool is that it can reduce latency. Setting this property to 0 disables the connection pool.
Default Value
10
Property
Attribute
kdb.connection.pool.ttl
Time to live in milliseconds for each connection instance created.
Default Value
30000
Property
Licensing
Attribute
license.hwu.hosted
Boolean stating if you wish to use Managed or Local Altair Units licensing. Set to true if you wish to use hosted licensing.
Default Value
false
Property
Licensing
Attribute
license.hwu.hosted.authorization.password
Password to the Altair One account.
Default Value
Property
Licensing
Attribute
license.hwu.hosted.authorization.token
An authorization token generated through the Altair One admin portal. Used to authorize a machine to the managed Altair Units system.
Default Value
Property
Licensing
Attribute
license.hwu.hosted.authorization.username
Username to the Altair One account.
Default Value
Property
Licensing
Attribute
license.hwu.uri
The path where the License Server is running e.g., 6200@191.255.255.0 where the syntax is PORTNUMBER@HOST. If multiple servers are specified, use the ‘;’ semicolon separator sign for Windows and the ‘:’ colon separator sign for Linux.
NOTE:
If value is not set in the Panopticon.properties, the environment variable ALTAIR_LICENSE_PATH serves as the backup path and will be used.
For Windows:
license.hwu.uri=6200@192.168.5.51;6200@192.168.5.52
For Linux:
license.hwu.uri=6200@192.168.5.51:6200@192.168.5.52
Default Value
Property
Licensing
Attribute
license.hwu.use_client_timezone
Determines how the ALJDK should process the timezone details. If set to true, the ALJDK will process the timezone details sent by Panopticon client to the Panopticon server. If set to false, the Panopticon server timezone is used.
Default Value
true
Property
Licensing
Attribute
license.hwu.version
Value must match the license version found in the Altair Units license file.
Default Value
19.0
Property
Licensing
Attribute
license.mode
The license mode. Possible values are: FILE or HWU. To use the Altair Units license, set this property to HWU.
Default Value
FILE
Property
Log level
Attribute
logger.level.file
Controls the level that is logged to file.
Default Value
INFO
Property
Server Metrics
Attribute
metrics.authorization.level
Specifies the required authorization level to get server metrics. Available values are ANONYMOUS, VIEWER, DESIGNER, ADMINISTRATOR.
NOTE: This property is case sensitive.
Default Value
ADMINISTRATOR
Property
Server Metrics
Attribute
metrics.collection.rate
Specifies the rate at which metrics are collected in milliseconds.
Default Value
1000
Property
Server Metrics
Attribute
metrics.file.flush.rate
Specifies how often metrics should be saved to disk in milliseconds. Only used if the metrics.publisher.type is set to FILE.
Default Value
10000
Property
Server Metrics
Attribute
metrics.memory.queue.size
Specifies how many metric entries are stored in memory. When the number of metrics goes above the specifies value, the oldest value is removed to make room for the newest one (FIFO). Only used if the metrics.publisher.type is set to MEMORY.
Default Value
100
Property
Server Metrics
Attribute
metrics.publisher.configuration
Specifies the id for which metric publisher configuration to use.
Default Value
Property
Server Metrics
Attribute
Specifies the current metric publisher that is used. Available values are NONE, MEMORY, FILE, EMAIL, INFLUX_DB, JDBC, KAFKA, KDB, MQTT, REST, TEXT.
Default Value
MEMORY
Property
Bookmarks repository
Attribute
repository.import.bookmarks.paths
Will import bookmarks from the old format into the repository. Will override any existing bookmarks inside the repository. Must be set to an absolute path. Only bookmarks for workbooks that exists inside the repository will be imported.
Default Value
Property
Workbook repository
Attribute
repository.migrate.archive.path
Use this property if you have an older (pre 2020) server and wish to start the new server with the same workbook content as the old one, and also to import the workbooks' change history from the old server. Set the property to the absolute path to the old server's <AppData>/Archive/ directory, delete the new server's <AppData>/.repository/ directory, and start the new server. You typically use this property with the repository.migrate.workbooks.path property.
See also the section on content migration.
C\:/vizserverdata/Archive
Default Value
Property
Attribute
repository.migrate.bookmarks.path
Will migrate bookmarks from the old format into the repository if there are no bookmarks inside the repository yet. Set to an absolute path or to the default Bookmarks folder. Only bookmarks for workbooks that exists inside the repository will be migrated.
NOTE: If you do not wish to migrate bookmarks or already have bookmarks in the repository, set this property to blank to avoid a warning on startup.
Default Value
Bookmarks
Property
Workbook repository
Attribute
repository.migrate.data.extracts.path
Starting with version 21.0, data extracts are stored inside the repository.
If this property is set to GlobalCaches (default value), or to an absolute path, the server will migrate data extracts into the repository on startup as long as the repository does not contain any previous data extracts.
NOTE: If you do not wish to migrate data extracts or already have data extracts in the repository, set this property to blank to avoid a warning on startup.
Default Value
GlobalCaches
Property
Data Templates Repository
Attribute
repository.migrate.datatable.templates.path
Will migrate data table templates from the old format into the repository if there are no data table templates inside the repository yet. Set to an absolute path or to the default Datatables folder.
NOTE: If you do not wish to migrate data table templates or already have data table templates in the repository, set this property to blank to avoid a warning on startup.
Default Value
Datatables
Property
Themes repository
Attribute
repository.migrate.themes.path
Will migrate themes from the old format into the repository if there are no themes inside the repository yet. Set to an absolute path or to the default Themes folder.
NOTE: If you do not wish to migrate themes or already have themes in the repository, set this property to blank to avoid a warning on startup.
Default Value
Themes
Property
Workbook repository
Attribute
Use this property if you have an older (pre 2020) server and wish to start the new server with the same workbook content as the old one. Set the property to the absolute path to the old server's <AppData>/Workbooks/ directory, delete the new server's <AppData>/.repository/ directory, and start the new server.
C\:/vizserverdata/Workbooks
Default Value
Property
Workbook repository
Attribute
repository.pack.enabled
The repository tracks all changes to all workbooks. If you have a very large number of workbooks, or have kept the repository for a very long time, the sheer number of files inside the .repository subdirectory could cause the repository to become slower. Set this property to true to have the repository pack all the files into fewer larger ones for faster access.
Default Value
false
Property
Repository
Attribute
repository.startup.apply.permissions.clean
Use this property with the repository.startup.apply.permissions.path to reset all existing workbook permissions on the server before applying the template. If you set it to true, the server will remove all permissions, then give users full permissions to their private folders, and the "Everyone" group full permissions to public folders.
Default Value
false
Property
Repository
Attribute
repository.startup.apply.permissions.create
Use this property with the repository.startup.apply.permissions.path to create empty workbook folders for any folders that are in the template file but do not yet exist on the server. If you don't set it to true, these folders from the template will be ignored.
Default Value
true
Property
Repository
Attribute
Use this property to make the server apply workbook folder permissions from a template JSON file on startup. Workbook folder permissions in the template will overwrite any existing permissions on the server. This property will not migrate permissions from an older (pre 2020) server, you need to use the PCLI convertpermissions to generate a template file from the old permissions first. See also repository.startup.apply.permissions.clean and repository.startup.apply.permissions.create.
Default Value
Property
Repository
Attribute
repository.startup.filesystemcheck
If set to true, server runs on startup to verify the repository integrity and reports any of the following issues:
·         a deleted /HEAD file,
·         a modified /HEAD,
·         a modified /refs/heads/master file,
·         any file deleted inside /objects/ (e.g., /objects/94/443eec118fb8bb2021071896ff7d386a9c9518),
·         any file modified inside /objects/.
NOTE: There may be dangling files in the /objects/ directory or those that are not in use. These files are typically results of failed saves and/or sync conflicts. The check may or may not detect deleted or modified dangling files, but that is not critical.
Default Value
false
Property
Repository Import
Attribute
repository.startup.import.paths
NOTE: Use this property to make the server import content at startup. This is imported on top of the existing content and will always overwrite anything that is already there. This property can be useful for example, if you have multiple servers with different content but you want the latest version of a standard set of workbooks to be deployed on all of them. This property only has effect on a stand-alone or leader server.
This property is the list of paths to directories and files, separated by the system specific path separator “;” on Windows and “:” on Linux. Each directory is scanned and imported keeping its local tree structure.
For example, workbooks to be imported are placed in a folder and in this property, the absolute path to that folder is specified.
ADDITIONAL NOTES:
·         User-specific folders (e.g., “~john/”) can be targeted this way, but only if they already exist on the server.
·         Bundles (exz files) directly listed in the property or found in directories listed are also imported, but always to the root, with their internal structure preserved.
·         Files that are not legacy workbooks or bundles are ignored.
·         The same set of workbooks will get imported over and over (startup, user edit, restart) and for bundles (nothing changes in the history the second time), but legacy workbooks change their meta data.
·         The import always overwrites local changes (it resets the workbooks in the repository).
Permissions are not supported, and any folders created will have “SYSTEM” as owner.
Default Value
Property
Request parameter mapping
Attribute
request.cookie.parameters.mapping.entry.delimiter
The delimiter that separates the configuration entries. This property will only affect incoming parameters.
Default Value
, (Comma)
Property
Attribute
request.cookie.parameters.mapping.optional
The parameters that could be updated with certain cookie values. This property will only affect incoming parameters. The operation will not fail if the cookie values are not present in the request. The parameters will keep their default value instead of the configured cookie value if the cookie is not present. The property should be formatted as follows: Parameter name (Value delimiter) Cookie name.
Default Value
Property
Attribute
request.cookie.parameters.mapping.required
The parameters that are required to be updated with certain cookie values. This property will only affect incoming parameters. The operation will fail if configured cookie values are not present in the request. The property should be formatted as follows: Parameter name (Value delimiter) Cookie name.
Default Value
Property
Attribute
request.cookie.parameters.mapping.value.delimiter
The delimiter that separates the parameter name and the cookie name. This property will only affect incoming parameters.
Default Value
: (Colon)
Property
Attribute
request.header.parameters.mapping.entry.delimiter
Default Value
, (Comma)
Property
Attribute
request.header.parameters.mapping.optional
The parameters that could be updated with certain header values. This property will only affect incoming parameters. The operation will not fail if the header values are not present in the request. The parameters will keep their default value instead of the configured header value if the header is not present. The property should be formatted as follows: Parameter name (Value delimiter) Header name.
Default Value
Property
Attribute
request.header.parameters.mapping.required
The parameters that are required to be updated with certain header values. This property will only affect incoming parameters. The operation will fail if a configured header values are not present in the request. The property should be formatted as follows: Parameter name (Value delimiter) Header name.
Default Value
Property
Attribute
request.header.parameters.mapping.value.delimiter
The delimiter that separates the parameter name and the header name. This property will only affect incoming parameters.
Default Value
: (Colon)
Property
Response parameter mapping
Attribute
response.operation.parameters.mapping.entry.delimiter
The delimiter that separates the configuration entries. This property will only affect outgoing parameters.
Default Value
, (Comma)
Property
Attribute
response.operation.parameters.mapping.optional
The parameters that could be updated with certain Header values. This property will only affect outgoing parameters. The operation will not fail if the Header values are not present in the request. The parameters will keep their default value instead of the configured Header value if the Header is not present. The property should be formatted as follows: Parameter name (Value delimiter) Header name.
Default Value
Property
Attribute
response.operation.parameters.mapping.required
The parameters that are required to be updated with certain Header values. This property will only affect outgoing parameters. The operation will fail if configured Header values are not present in the request. The property should be formatted as follows: Parameter name (Value delimiter) Header name.
Default Value
Property
Attribute
response.operation.parameters.mapping.value.delimiter
The delimiter that separates the parameter name and the Header name. This property will only affect incoming parameters.
Default Value
: (Colon)
Property
REST
Attribute
rest.response.error.stacktrace.included
Include the error stack trace in REST responses.
Default Value
false
Property
Compatibility
Attribute
server.force_downgrade
The server normally refuses to start if it detects that the AppData directory has been used by a server with a newer version. This is because downgrading content and other AppData files is not supported and can cause irreversable issues. You can set this property to true to force the server to start anyway, but it is strongly recommended that you do not.
Default Value
false
Property
Email
Attribute
server.host
The server endpoint address. This will be used to generate links in emails sent by the server, so it should be the server's or load balancer's public URL and needs to be resolvable from the email recipient's machine. For example:
server.host=http://www.company.com/dashboards/
Default Value
Property
PDF and Image generation
Attribute
server.host.internal
The local server endpoint address. To generate PDFs and images, the server fires up an external process which then makes HTTP calls to the server itself. This URL needs to be resolvable on the server itself. For example:
server.host.internal=http://127.0.0.1:8080/panopticon/
Default Value
Property
Server
Attribute
server.id
Specifies an id for the current server. The value of this property will be part of each metric entry so that it can be tied to a specific server if a server cluster is used. If no value is specified, the MAC address of the localhost network will be attempted to be used to identify the server. If this is not possible, a UUID will be generated.
Default Value
Property
SOAP
Attribute
soap.enabled
Enable or disable the SOAP interface
Default Value
true
Property
Data table regression testing
Attribute
startup.regression.datatable.exclude.folders
Comma-separated list of folders that will be excluded in the testing.
Use this property in combination with the startup.regression.datatable.include.folders property to control which workbooks to include in the testing. For example, you can set startup.regression.datatable.include.folders to "pub\\" and startup.regression.datatable.exclude.folders to "pub\\examples\\,pub\\temp\\".
Default Value
Property
Attribute
Comma-separated list of folders to test.
The default is blank, which means the root folder and all workbooks will be tested. If you list folders here, then only the data tables in workbooks in these folders will be tested, unless also excluded. Folder paths should include a trailing backslash, and you need to use double backslashes since this is the escape character in Java property files. For example, to only include prod and qa\final, you should set the property to "prod\\,qa\\final\\" (without quotes).
Default Value
Property
Attribute
startup.regression.datatable.runonce
If set to true, the server will run a data table regression test during the next startup. The property is immediately reset to false, so you need to set it to true again to run another test.
NOTE: You can set the property through an environment variable if you want to force the server to run it on every startup.
Default Value
false
Property
Authorization
Attribute
statistics.authorization.level
Allows users to set the authorization level for the statistics and diagnostic REST services. Possible values include: ANONYMOUS, VIEWER, DESIGNER, ADMINISTRATOR.
Default Value
ADMINISTRATOR
Property
Statistics
Attribute
statistics.accumulated.enabled
By default, the server accumulates statistics from every run into files in <appdata>/Statistics/, e.g., WorkbookStatistics_Accumulated.json. You can delete these files if you are not interested in this information, or you can set this property to false to disable the accumulation completely.
Default Value
true
Property
Subscription
Attribute
subscription.broadcasting.pool.max.size
The maximum number of threads for the broadcasting thread pools of refresh events.
The default value is empty, which means that there is no limit. Any value less than 1 also means that there is no limit. When setting a max value for the thread pools, it means that the pool cannot create more than that number of threads. If there are more concurrent events handled by the thread pools than there are threads, they are queued until a thread becomes available.
The thread pools are also configured to only increase the pool size if all threads are busy and a new event needs to be processed. If a thread is idle more than 1 minute, it will be removed from the pool and the size of the pool thereby decreases.
Any subscription for a static data source are scheduled to refresh each X seconds (based of the refresh period of the datatable) using the TaskScheduled built in to Spring.
If multiple subscriptions with the same data query tries to load data at the same time, only one thread will actually load the data. The rest of the subscriptions are queued. When the data is loaded all waiting subscriptions will be given the same data set that are then broadcasted to their respective client.
Default Value
Property
Subscription
Attribute
subscription.compression.delta.enabled
With delta compression, the server only sends the difference from the last data result on each refresh. For data where only a fraction changes on each refresh, this means much smaller response messages.
The trade-offs are that both client and server need to keep the last result to calculate the difference and apply it, and that this operation takes some additional time both on the server and the client.
In rare cases, delta compression may worsen performance, e.g., if you have a large data set with very high refresh rate and a large portion of the data changes on each refresh. You can then disable delta processing completely by setting this property to false.
Default Value
true
Property
Subscription
Attribute
subscription.compression.enabled
Enable or disable compression and encoding of subscription broadcast messages.
Default Value
true
Property
Subscription
Attribute
subscription.congestion.control.enabled
When the server loads data for a subscription, it checks that the previous data load for it has completed. If not, it might be a sign that the refresh rate is set too high on the data table. If this happens subscription.maximum.failure times in a row, the server will cancel the subscription. Set this property to false to disable this behavior.
Default Value
true
Property
Subscription
Attribute
subscription.data.loading.pool.max.size
The maximum number of threads for loading thread pools of refresh events.
Any subscription for a static data source is scheduled to refresh each X seconds (based of the refresh period of the data table) using the TaskScheduled built into Spring.
Default Value
Property
Subscription
Attribute
subscription.data_log.always_on
When set to true, the data log is always passed from server to client if the user is a Designer or Admin on the server. Previously, the data log would only be passed for workbooks in design mode.
The data log will be passed also when the data request fails. The “Invalid Configuration” message shown in the visualization will show a “Data Log” button, which will display the relevant logs and error message.
NOTE: The actual passing of runtime exception is currently implemented in the Kdb+ connector only.
The benefit of running a server with subscription.data.log.always_on=true is that, the data log is more easily accessed and can be viewed both as success and failure. The data log can also be viewed without having Write permissions on the folder where the workbook is used, which is helpful when connection failures need to be examined in production environments where you have restrictions on workbook editing.
NOTE: Viewer users are not able to view the Data Log, only Designers and Admins.
Default Value
false
Property
Subscription
Attribute
subscription.limitation.action
Controls the behavior when the subscription.limitation.limit is reached. Allowed values: EXCEPTION, PURGE
Default Value
EXCEPTION
Property
Subscription
Attribute
subscription.limitation.enabled
Enables limitation of subscriptions.
Default Value
false
Property
Subscription
Attribute
Defines a subscription limit.
Default Value
100
Property
Subscription
Attribute
subscription.log.slow.data.loads.seconds
Logs a subscription that has been loading data for more than X seconds at a WARNING level.
NOTES:
·         Any integer less than 1 (or an empty value) will disable the logging.
·         If a slow data load has been logged and then returns data, a log message at INFO level will be printed stating that a previously logged slow data load has returned data.
Default Value
60
Property
Subscription
Attribute
The amount of time a subscription is allowed to fail in a row before it should be cancelled. The number will be reset to zero if data loading is successful. The maximum failure limit is used so that invalid subscription will not loop forever and fill the logs with error messages. The value -1 will disable the fail mechanism. This means that a subscription can fail endless of times and not be cancelled.
Default Value
5
Property
Subscription
Attribute
subscription.purge.condition
Defines the condition for when subscriptions will be purged. Allowed values: NONE, MEMORY
Default Value
NONE
Property
Subscription
Attribute
subscription.purge.condition.memory.threshold
Defines a percentual memory threshold for subscription purging, when the subscription.purge.condition = MEMORY.
Default Value
80
Property
Subscription
Attribute
subscription.purge.enabled
Enables subscription purging.
Default Value
true
Property
Subscription
Attribute
subscription.purge.post.restart
Option to re-start active subscriptions after purge. Only valid when subscription.purge.scope = ALL
Default Value
false
Property
Subscription
Attribute
subscription.purge.rate
Defines a fixed rate, in milliseconds. for subscription purging.
Default Value
10000
Property
Subscription
Attribute
Defines the scope of subscriptions to purge. Allowed values: NON_PERSISTENT_ORPHANS, ALL.
Default Value
Property
Timeout Session
Attribute
timeout.session.enabled
Boolean value stating if timeout functionality should be used or not.
Default Value
false
Property
Timeout Session
Attribute
timeout.session.exception.delimiter
The delimiter to use for the usernames stated in the timeout.session.exception.usernames property.
Default Value
, (comma)
Property
Timeout Session
Attribute
Usernames that should be excluded from the timeout functionality. Separated by the delimiter stated in the timeout.session.exception.delimiter property.
Default Value
Property
Timeout Session
Attribute
timeout.session.minutes
Minutes of inactivity before a user session is terminated by logging out the user.
Default Value
480
Property
Timeout Session
Attribute
timeout.session.notification.minutes
Minutes before a timeout that a notification about session timeout is sent to the user.
Default Value
1
Property
WebSocket Connection
Attribute
transport.buffer.size.max.bytes
Maximum size of message buffer for the WebSocket connections.
Default Value
10000000
Property
Attribute
transport.message.size.max.bytes
Maximum size of messages for the WebSocket connections.
Default Value
1000000
