[1] Introduction
Overview
Altair Panopticon Real Time supports the following data connectors:
q General Connectivity: MS Excel, Text, XML, JSON, Restful Web services, JDBC Databases
q Big Data: Cassandra, Elasticsearch 6.x, Elasticsearch 7.x, KsqlDB, Livy Spark, MongoDB, Splunk
q Event Processing: Kx kdb+Tick, OneMarketData OneTick CEP, Tibco Streambase, Tibco LiveView,Panopticon Streams
q Messaging Streaming: Apache/Confluent Kafka, JMS (e.g., ActiveMQ), Solace, RabbitMQ, WebSocket, JMX, Google Cloud Pub/Sub, MQTT
q Tick Data: OneMarketData OneTick, OneTick Cloud, Kx kdb+, InfluxDB
q Custom code data connections, transforms, and ML model scoring: Python, R, and REST service calls
In addition, Panopticon Real Time includes a Panopticon bundle file of example workbooks (Examples.exz). To use the example workbooks, the bundle file must be imported into the server after the server installation.
NOTE |
· Beginning with version 17.1, MS Access, Valo, Apache Qpid, Valo Streaming, Ultra Messaging Streams, and OData connectors are deprecated. · Beginning with version 16.2, DataDirect based connectors, along with Vertica, are deprecated. The Database connector or JDBC Database connector should be used. · Existing workbooks will continue to operate, but connectivity will need to be migrated for subsequent releases. |
Version 2023.1/06.2023
