Altair® Panopticon
Scheduling Tasks
On the Scheduler tab of the System Settings page, Panopticon Real Time allows scheduling of tasks.
A new scheduled task is added in the list with the properties.
Scheduler Property
Run Task
Manually run scheduler task.
2
Upload Task
Upload scheduler task.
3
New Task
Create a new scheduler task.
4
Delete Task
Delete a scheduler task.
5
Download Task
Download a scheduler task.
6
Task Properties
The task properties include:
·        Name of the task
·        Activated status
·        Type of the scheduled task
·        Trigger type: Period or CRON
·        Last user who made an update
·        Date/Time when the task was created
·        Date/Time when the task was last ran
·        Last run result: Success or Failed
For failed results, you can hover on the tooltip to view the error.
NOTE: The result is not displayed for Extract Data scheduler type.
To create a new task, click . The New Task pane displays that allows you to define the following tasks:
q     Clearing and Importing Data Table to Data Store
q Sending of a CSV Data via Email
q Sending of an MS Excel file via Email
q Sending of an HTML Formatted Data via Email
q Sending of an Image file via Email
q Sending of a PDF file via Email
q Extracting Data
     NOTE
·         To allow scheduling of email send outs, Panopticon Real Time must be configured with valid email server information in the Panopticon.properties file located in the AppData folder (e.g., c:\vizserverdata).
See Panopticon Real Time Configurations for Email Send Outs and Alerts for instructions.
·         If any data load fails, such as when the data source is offline, the PDF/Image generation fails as well and an email will not be sent.
