Altair® Panopticon
Create Task to Import Data Table to Data Store
Allows you to store data closer to Panopticon server in an embedded database.
1.      On the New Task pane, enter the Name of the task. Ensure the name is unique.
2.      Tap the Activated slider to turn it on.
3.      Select the Trigger. You can either select:
·        Period then enter the Interval (in seconds), or
·        CRON then enter the CRON Expression.
4.      Select the task Type: Data Store – Import Data.
5.      Enter the Description of the task.
6.      Select the Data Table Name that will be imported in the data store.
7.      Click .
·        Once saved, you can opt to click  to manually run the task.
·        Click  to go back to the Tasks pane. The new task is added in the list.
