Altair® Panopticon
[13] Alerting
The Alerts function allows a notification to be sent when the data in a visualization has met the predefined settings.
If alerts are required to be sent via email, Panopticon Real Time must be configured with valid email server information in the Panopticon.properties file located in the AppData folder (e.g., c:\vizserverdata).
See Panopticon Real Time Configurations for Email Send Outs and Alerts for instructions.
Otherwise, when trying to enable an alert, this error will be displayed:
In addition, you can also set the alert.creation.only.by.administrators property to true to only enable Administrators to create alerts.
