Altair® Panopticon
[9] Data Templates
After the user with a Designer role successfully retrieves the data table using the Panopticon connectors and can publish it as a data template that:
q  can be used by other users with granted permissions to create workbooks
q  allows the changes in the data template to be appended to existing workbooks
For more information on how to save and publish a data table template, refer to Publishing a Data Table Template section in the Altair Panopticon Web Authoring Guide.
    NOTE
Starting with version 21.2, data table templates are stored inside the repository and synced between servers in a cluster.
On the Data Templates page, Administrators can:
q  View the list of published data table templates
 Search, sort, upload, rename, move, copy, download, or remove data table templates
 View the data template usage
 Update the referring workbook using the data template
