Saving a Pre-Processing Project
Preprocessing projects, including indoor/urban databases as well as any associated secondary data such as topography maps, can be exported from WallMan as a ZIP archive.
A pre-processing project can be saved using
or . These operations can write absolute file paths, which is a disadvantage if you want to move or copy the project to a different location. For such situations, the option should be used. The zip file can be extracted in a different location.
