Why Pre-Processing?
Nearly all wave propagation predictions require a few computations that are different for each database but the same for all transmitters. For example, the visibility relations between buildings never change, no matter what kind of antenna pattern or how much output power the transmitter uses.
To decrease computation times WallMan performs such computations just once for each database so that ProMan can use this computation for the actual predictions later.
