Drag Mode
Whenever you have not finished an editing operation the drag mode is active. For example, if you move objects or if you have set the first point of a line and now moving the cursor to the second point. You may abort the drag mode at any time by pressing the Esc key.
Various zoom functions (Zoom In, Zoom Out and Fit to Screen command) and the auto scroll mode makes it easy to navigate through the drawing while drag mode is active.
