Document Conventions
The WinProp User Guide makes use of a number of conventions to help you quickly learn about Feko.
- Hyperlinks are indicated in blue.
- Text cited from the GUI interface, are written in bold text, for example, Default Settings.
- A combination of keystrokes is joined with the
sign, for example, Alt+Shift+O. - To draw your attention to important information, the information is marked as a
note, tip or warning, for example:Note: This is a note to draw your attention to critical information.
