WinProp Applications
WinProp is used in, but not limited to, the following applications:
- Automotive - antenna evaluation
- Analysis of car-antenna performance along a trajectory using a virtual drive test or a simulation with explicit time variance. In a virtual drive test, one evaluates wireless connectivity along a trajectory, for example, a trajectory of several kilometers length near an LTE base station in a (sub)urban scenario. While the antenna moves, the geometry is stationary. In a simulation with explicit time variance (usually on a smaller scale), car traffic is explicitly present and moving as well.
- Telecommunication - radio network planning for urban scenario
- Analysis of a radio network in an urban scenario. For example, you can optimize the network coverage of a cellular network while taking into account the effects of buildings, vegetation and topography.
- Telecommunication - indoor radio network planning
- Analysis of a radio network indoor. An example includes optimizing a WiFi network to give the best coverage inside an office building.
- Wireless Sensors - planning of sensor networks
- Connectivity analysis of wireless sensor networks that monitors physical or environmental conditions. An example includes the placement of a sensor network inside an industrial environment to automate assembly lines.
- Railway - in-cabin radio coverage
- Connectivity analysis of the transmit antennas in a train. An example includes optimizing the WiFi network in-cabin and also taking into account the seats and a separate room.
- Aerospace - airport radio coverage
- Analysis of radio coverage at airports between the terminals and aeroplanes. An example includes the coverage of an aeroplane that as it moves away from the terminal to the runway.
