Horizontal Antenna Patterns
The 2D horizontal pattern is displayed with top view. The angle stretches from 0 to 360° and is oriented counter-clockwise.
The direction of 0° is describing the direction with maximum gain. But this is not mandatory. Also, other directions can be used. But as the direction of 0° is often visualized in radio planning tools, it helps the network planner if the main energy is also radiated in this direction.
Table 1. File extensions of the horizontal antenna patterns.
Extension Meaning
.ahb Antenna pattern horizontal binary
.aha Antenna pattern horizontal ASCII
