Wall
In the configuration antenna in front of a wall the wall is important and must, therefore, be modeled accurately with the following parameters:
  • Planar object with a rectangular shape (quadrate).
  • Length of the side of the quadrate (user defined).
  • Material properties (reflection and transmission loss) (user defined).
  • Smooth surface (only specular reflection, no scattering).
