Keyboard Shortcuts
Define shortcuts to common operations.
File
To do this | Press |
Open | Ctrl + O |
New | Ctrl + N |
Import | Ctrl + I |
Save | Ctrl + S |
Save As | F12 |
Save All | Ctrl + Shift + F12 |
Save a Copy As... | F9 |
Save Selected | Shift + F12 |
Close | Ctrl + W |
Close All | Ctrl + Shift + W |
Exit | Ctrl + Q |
Edit
Redo | Ctrl + Y |
Undo | Ctrl + Z |
Copy | Ctrl + C |
Cut | Ctrl + X |
Paste | Ctrl + V |
Delete | Delete |
Rename | F2 |
Duplicate | Ctrl + D |
Switch | Ctrl + T |
Edit Blocks
Super Block | Ctrl + B |
Expand Super Block | Ctrl + Alt + X |
Show Name | Ctrl + L |
Flip | Ctrl + F |
Rotate Right | Ctrl + R |
Rotate Left | Ctrl + Shift + R |
Auto Mask | Ctrl + M |
Remove Mask | Ctrl + U |
Restore Mask | Ctrl + Shift + M |
Left | Ctrl + Shift + L |
Right | Ctrl + Shift + R |
Bottom | Ctrl + Shift + Down |
Top | Ctrl + Shift + Up |
Vertical | Ctrl + Shift + V |
Horizontal | Ctrl + Shift + H |
Simulate
Run | Ctrl + E |
Compile | Ctrl + Alt + C |
Tools
To open | Press |
OML Editor | Ctrl + H |
Model dialog | Ctrl + Alt + M |
Context dialog | Ctrl + Alt + D |
Setup dialog | Ctrl + Alt + S |
Debug File Viewer | Ctrl + Shift + D |
View
To view | Press |
Maximize Window | Ctrl + Alt + 6 |
Restore Window | Alt + Shift + X |
Full Screen | Shift + F11 |
Split Vertical | Ctrl + Alt + V |
Split Horizontal | Ctrl + Alt + Z |
Split Window | Ctrl + Alt + W |
New Window | Ctrl + Alt + N |
Help
To open | Press |
Help | Ctrl + F1 |
Miscellaneous
Close All (Ignore Messages) | Ctrl + Shift + F4 |
Dock Windows
To open | Press |
Project Browser | Ctrl + F2 |
Property Editor | F3 |
Python Window | F4 |
Command History | Ctrl + Alt + H |
Variable Browser | Ctrl + Alt + R |
OML Command Window | F8 |
File Browser | Ctrl + Alt + F |
Demo Browser | F7 |
Modifying Keyboard Shortcuts
You can modify the default keyboard shortcuts in the Preferences dialog.
- From the menu bar, select .
- In the Preferences dialog that appears, under Category, select Keyboard Shortcuts.
- Select a shortcut that you want to modify and enter a new value.
