Importing Libraries into Arduino IDE
Import Arduino libraries using the Arduino IDE library manager.
- Run the Arduino.exe to start the Arduino IDE.
- Select .
In the Library Manager Search box, enter the full or partial name of the
library for which you want to search.
Note: Some libraries require that you select a version before you can install them.
- Click Install. The library downloads to the default installation path: C:\Users\<user-name>\My_Documents\Arduino\libraries.
