Set Up Grids
The application has four different grids, each with successively larger spacing. Grids are drawing aids used to place and align points and objects with precision. They do not appear in rendered images.
Change the Grid Settings
Change the spacing, appearance, and color of the four grids.
- On the File menu, click the Preferences button.
- Under the Category of Inspire Studio, click Snaps.
spacing. You can define the following:
- The spacing between grid lines in the x, y, and z direction.
- The appearance of the grid: Points, Crosses, Continuous.
- The color of the grid.
Show or Hide the Grids
Show or hide the grids in all modeling views, the perspective view, or the orthogonal views.
You can do the following:
| To | Do this |
| Show/hide grids in all modeling views | In the view controls, click Grid
On/Off
| Show/hide grids in the orthogonal views |
| Show/hide grids in the perspective view |
